ayuda ASUS P5Q-E overlock!!! sacar unos 1200mhz para las memos :D
dwn249
entradas: 12
18:43 10/08/2009
Hola gente bueno actulize algo mi pc y tengo una ASUS P5Q-E y un Q6600(vid 1.3250v),
4 GB G.Skill 1066 MHZ (2.0v-2.1v), venti xigmatec hdt-1283
quisiera una guia o ayuda para mejor mi overlock y lograr unos 1200mhz en la memos y no se unos 3200ghz para el proce aun k ya lo logre pero no puedo con las memos
o algo parreciido
Gracias de antemano ayuda!ª
mi bios
AI Overclock tuner: AUTO
CPU Ratio Setting: AUTO
FSB Strap to North Bridge: 266 Mhz
FSB Frequency: AUTO
PCI-E Frequency: 100
DRAM Frequency: DDR2-1066 ->>> como sakaria unos *1200mhz* :S
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: ENABLED
DRAM Read Training: DISABLE
MEM. OC Charger: ENABLED
AI Clock Twister: Moderate
AI Transaction Booster: AUTO
Common Performance Level [05]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: AUTO
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: AUTO
FSB Termination Voltage: AUTO
DRAM Voltage: 2.10
NB Voltage: AUTO
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: AUTO
CPU Spread Spectrum: AUTO
PCIE Spread Spectrum: AUTO
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
C1E Suppport: Enabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Enabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
mi proce a 3200mhz me ekivoke en el multi por unos puntos:S http://www.subirimagenes.com/otros-3…h-3024160.html
Christoph
entradas: 1334
19:04 13/08/2009
te recomiendo primero busques guias de oc en google, incluso aqui en el foro hay un par para oc en INTEL
para empezar con algo, si queires hacer OC
tienes que deshabilitar las opciones de CPU Spread Spectrum y del PCI, todo lo que tengas de Spread spectrum tienes que deshalibilitarlo.
tmabien tienes que deshabilitar el soporte C1E.
de ahi, para logar mas estabilidad en el OC, tienes que insertar todos los datos de la ram manualmente, no solo CAS o RAS
y si quieres hacer OC a las memos tendrias que elevar el valores que tuvieras por default.
es decir si tienes es CAS= 5 tendrias que ponerlo a 6
y asi en todos las caracteristicas, osea aflojar los valores
1- Para tener más variedad de divisores de RAM necesitás dejar el strap en AUTO. Con eso liberás más frecuencias. De todos modos a 1200 no llegás ni en pedo, es más, dudo que consigas más de ~ 1100/1120 con suerte a vdimms decentes.
2- Empezá usando un voltaje para la memoria de 1,95v, ya que el mother overvoltea unos 0,08v aprox.
Basicamente inentaría para empezar unos 3200 mhz de ésta manera:
AI Overclock tuner: MANUAL
FSB Strap to North Bridge: AUTO
FSB Frequency: 356
DRAM Frequency: andá acomodando valores que te ronden los 1070 a 1100
1st Information :
CAS# Latency: 5
2nd Information :
3rd Information :
DRAM Static Read Control: DISABLED
AI Clock Twister: STRONG
CPU Voltage: 1,3250
CPU PLL Voltage: 1,50
DRAM Voltage: 1,95
NB Voltage: AUTO
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Si todo anda bien, el micro no calienta tanto y es estable más tarde podrás jugar con más tiempo en base a prueba y error como para hacer unos 3400 mhz con memorias al máximo. Lo mismo con el tema voltajes, nada está definido.
