un problema con los juegos basado en el engine del quake 3
Warrior_oF_Byte
entradas: 302
02:31 03/03/2005
todos los juegos que probe con el engine del quake 3, SoF, RCW o el Q3… me
Tengo el driver del SP2 de Xp… y direct 9c.. y me hace lo mismo si instalo otro driver mas nuevo..
tiran un error como este en la consola de carga
SOF2 1.00 win-x86 May 3 2002
Initialising zone memory …..
——- Filesystem Initialization ——–
Current search path:
e:/soldie~1/base/therest.pk3 (7125 files)
e:/soldie~1/base/textures1234.pk3 (10843 files)
e:/soldie~1/base/textures0.pk3 (2816 files)
e:/soldie~1/base/skins.pk3 (4117 files)
e:/soldie~1/base/musicandsound.pk3 (3055 files)
e:/soldie~1/base/mp.pk3 (338 files)
e:/soldie~1/base/models.pk3 (3643 files)
e:/soldie~1/base/maps.pk3 (466 files)
E:\SOLDIE~1/base
32403 files in pk3 files
couldn't exec myconfig.cfg
Precaching string packages …
… 3173 strings precached
———- Getting System Info ———–
OS: Microsoft WinXP Service Pack 2 (NT)
RDTSC instruction supported
3dNow! enabled processor
SSE2 enabled processor
Extended name: AMD Athlon(tm) 64 Processor 3000+
AMD running at 1807 MHz
1023MB physical memory available
——— Client Initialization ———-
Loading renderer…..
——— Initializing Renderer ———-
WARNING: cvar 'r_lodbias' out of range (-1.000000 < 0.000000)
Initializing OpenGL subsystem
…initializing QGL
…calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
Checking for ARB multisample … GL_ARB_multisample not found
…setting mode 3: 640 480 FS
…using desktop display depth of 32
…calling CDS: ok
…registered window class
…created window@0,0 (640x480)
Initializing OpenGL driver
…getting DC: succeeded
…GLW_ChoosePFD( 32, 24, 8 )
…35 PFDs found
…GLW_ChoosePFD failed
…GLW_ChoosePFD( 32, 24, 0 )
…35 PFDs found
…failed to find an appropriate PIXELFORMAT
…restoring display settings
…WARNING: could not set the given mode (3)
…using colorsbits of 16
…calling CDS: ok
…GLW_ChoosePFD( 16, 16, 0 )
…35 PFDs found
…35 PFDs found
…shutting down QGL
…unloading OpenGL DLL
Error during initialization SYSTEM ERROR
GLW_LoadOpenGL() – could not load OpenGL subsystem
————- Input Shutdown ————-
ayuda plz…
Hello NOKIA, punchi punchi!! (8)
Billy The Kid
entradas: 4045
02:41 03/03/2005
Tenes que instalar los drivers de Nvidia… porque ese drivers de xp no trae soporte de OpenGL .. esa es la Api de aceleracion q usa ese engine..
si tenes placa Ati bajate los nuevos Catalyst de la pagina de Ati para q funcione-
es asi de simples.. saludos
Warrior_oF_Byte
entradas: 302
02:57 03/03/2005
ok ok intentare con el 66.93 o algo asi.. que por aca lo tengo.. si no funcan.. jodo de nuevo.. pero ya recuerdo haberlo intentado y no way…
Billy The Kid
entradas: 4045
03:25 03/03/2005
no way ?? proba y contame..
entradas: 3608
19:56 04/03/2005
parece que te falta los controles de inicializacion del api (del opengl)., como te dijo kaiser, proba con los ultimos drivers haber que pasa….
Warrior_oF_Byte
entradas: 302
23:34 04/03/2005
SEÑORES!!!
me quito el sombrero y os saludo…
He probado con los 66.93 y funciona de las mil maravillas
Muchisimas gracias…
Warrior_oF_Byte a sus ordenes…
GRM
entradas: 5
00:30 07/03/2005
A esto me viene una duda…
¿Porqué Microsoft trae drivers tan "recortados" de estas cosas, al igual que con algunas placas de sonido, y demás?
(Sabiendo que solo integran los WHQL)
MuTaY
entradas: 3027
11:41 07/03/2005
Cita Iniciado por Warrior_oF_Byte
SEÑORES!!!
Muchisimas gracias…
Proba los 71.40 q uso yo (tan en http://www.guru3d.com)
o tambien podes probar los 71.80
Ya q a mi los 66.93 me trajeron problemas con algunos juegos.
Mmm que rico!
