Arctic Cooling Low Profile Dual Fan CPU Cooler
josr
entradas: 3366
23:33 28/02/2007
Encontre este articulo en VR-Zone, parece ser dos coolers identicos unidos por su base para sockets AM2 y 939.
Les dejo una foto y el texto en ingles del articulo completo.
ARCTIC COOLING launches an innovative low profile dual fan CPU cooler – Freezer 64 LP for AMD CPU and low profile PC. The design of Freezer 64 LP ultra high performance dual fan achieves the ultimate cooling effect that dramatically cools the AMD CPU even inside a tiny chassis. Freezer 64 LP’s 2 vertical cooling fans draw a large amount of cold air from both sides that cool the CPU fast and effectively. 3 copper heat pipes directly connected from the CPU core transfer heat out of the core rapidly.
Additionally the design of the Freezer 64 LP cools the surrounding chipset and voltage regulators and operates at just 1/3 of the noise level as the stock cooler and this even under heavy loading. Freezer 64 LP definitely gives the ideal cooling solution for high performance low profile HTPC applications. Freezer 64 LP is widely compatible with AMD socket 939 or latest AMD AM2 CPUs. Same as the other ARCTIC COOLING products Freezer 64 LP users can enjoy a 6 year limited warranty. Freezer 64 LP will be available by end of March 2007. The MSRP is USD 24 or Euro 20 (excl VAT).
Fuente VR-Zone: http://www.vr-zone.com/index.php?i=4708
Stephen Jay Gould
Habra que ver que desempeño y performance tiene este bicho.. que peso tiene?
Tramendo cooler para ser low profile. Debe ser muy pesado, pero tiene pinta de enfriar muy bien. Habra que esperar a que salga para ver que tal es.
josr
entradas: 3366
09:28 01/03/2007
Cita Iniciado por BNDMOD
Ni idea, no decia
Stephen Jay Gould
La verdad no me covence el diseño, se nota que tiene pipes entre los disipadores pero justamente eso es lo que no me gusta, no es lo mismo a que tenga los fins estre los pipes. Igual habria que ver una review.
Salu2…
ecibad
El diseño no es de lo mejor para mi gusto.. por el tema de los pipes en el medio.. pero habria que ver que tan eficiente es… me encantaria tener una review de esto.
