Problema Norton Ghost – No puedo crear una imagen del disco
leansms
entradas: 1417
14:35 11/08/2009
Estoy queriendo hacer una imagen de un disco rigido aparentemente es Ide, aun no lo desarme, pero cuando quiero usar el norton ghost, es como que quiere cargar controladores y fallan, y despues cuando termina todo, voy a ver si puedo crear una imagen de la particion C y me tira esto:
there valid source drive choose 11032
Encontre en ingles algo, pero no entiendo q hacer, miren:
Error: Error 11032: "No valid source drive to choose" when using the GhostCast server
Question/Issue:
You are using the GhostCast server. The client starts up, gets its IP from DHCP, accepts a session name, but hangs before selecting the drive to image.
Cause:
Incompatibility issues with DOS and the hard drive.
Solution:
There are multiple possible solutions. Try each one below.
* Add the parameters -FNI -FFX -FNU -NOIDE -NOUSB
* If you are using a Broadcom NIC, make sure you have the latest DOS driver by following the instructions in the following document:
"Adding or modifying NIC templates in the Ghost Boot Wizard." at:
http://service1.symantec.com/SUPPORT…00011211551725
* Try WinPE.
o If you have Ghost Solution Suite 2.0 or earlier follow the below document:
"How to build a Windows PE [Vista] CD/DVD that contains Ghost32.exe and then join a client computer to a GhostCast Server session to create or restore an image file." at:
http://service1.symantec.com/SUPPORT…07120608081560
o If you have Ghost solution Suite 2.5 or newer follow the directions in the below document:
"How to make a Windows PE boot package with the Ghost Boot Wizard." at:
http://service1.symantec.com/SUPPORT…08050911464460
* This error is also seen with Ghost32.exe when trying to image a RAID 1 device. The mirror may need to be broken before imaging occurs.
* Changing the BIOS setting for the SATA controller to Combination mode allowed ghost to get past this error and see the drive.
* Disabling USB Emulation in the BIOS may also resolve this issue.
ALGUIEN ENTIENDE QUE PASA? Capaz hay algo en el bios que debo modificar pero no se que es.
El bios es parecido a este
No tengo idea donde ir,
ustedes?
maguilla
entradas: 4148
14:52 11/08/2009
Usa acronis true image que va como trompada
juansaba
entradas: 100
15:05 11/08/2009
Cita Iniciado por maguilla
Totalmente de acuerdo…mucho mas fácil y mas rapido!
"Yo soy Peperino, mártir latino, venid al asado pero traed el vino"
Emancipate yourselves from mental slavery….None but ourselves can free our minds…
leansms
entradas: 1417
15:40 11/08/2009
Che estoy viendo y este programa crea la imagen del disco en la interfaz de windows?? no es medio inestable hacer esto si esta andando la pc? Va se me hace que en DOS es mas seguro hacer una imagen, pero ni idea
maguilla
entradas: 4148
15:47 11/08/2009
Cita Iniciado por leansms
nuuu para nada vieja…..hace instalacion nueva, pone a hacer la imagen y solito la larga….
Slds!!
andres2420
entradas: 880
16:00 11/08/2009
Todo es mejor haciendo las cosas "a bajo nivel"…anda y descargate el Hirens Boot que tenes dentro de las opciones muchos programas para hacer las copias espejos de discos y particiones.
Yo use el ghost 8 y pico que viene en el cd del hirens vercion 9.9 y pase una particion de un disco ide a uno sata en 20 minutos, con un tamaño de 41gb no tune dramas.
Andrés
leansms
entradas: 1417
16:03 11/08/2009
Slds!!
A okk, y una cosa mas, me confunde aca una cosa, yo quiero clonar una particion con todo C, drivers, como lo hacia con el Norton Ghost, y veo 2 opciones parecidas en en programa q instale en español
Una es en Utilidades, hay una opcion que dice clonar disco , dice que puedo clonar laparticion de un disco seleccionado a otro disco
Despues hay una opcion en INICIO – Realizar copia de seguridad – Mi equipo ( crea una imagen del disco duro completo o una particion)
Cual es la mas parecida a norton ghost? o sea cual elijo para que en caso que falle windows recuperarlo desde la imagen
maguilla
entradas: 4148
16:08 11/08/2009
Copia de seguridad….y ahi te deja hacer una imagen….la primera opcion es para cuando te compras un segundo HD nuevo y queres pasar un disco al otro..igual chequea el tutorial que tiene que esta terrible
Slds
leansms
entradas: 1417
16:11 11/08/2009
Slds
ok gracias!!!!
Slds
Igual me queda la duda de como hace la imagen si hay archivos esenciales de windows que estan siendo usados por windows al tener prendida la pc y tenerla asi como si estaria usandola normalmente
maguilla
entradas: 4148
16:41 11/08/2009
ok gracias!!!!
Fijate que durante la instalacion da de alta unos servicios, chequea la lista de servicios y vas a ver que hay uno que dice Acronis mirror server o server image una gilada asi…
Usa ese service para generar la copia de los archivos en uso
Obviamente para que el proceso sea mas rapido yo la dejo de usar mientras esta haciendo la copia
andres2420
entradas: 880
01:21 12/08/2009
Te reitero que todo es mejor hacerlo a bajo nivel, estas clonando un disco completo, no es cosa de todos los dias.
Bootea con un live cd y hacelo pero hacelo sin usar windows…tomalo de alguien que muchas veses ah usado el ghost para clonar por red, o de un simple disco a otro, de una particion a otra.Posta
Un abrazo grande
Andrés
maguilla
entradas: 4148
09:35 12/08/2009
No es mejor ni peor….He clonado varias veces del acronis y la verdad un chiche como funciona, restaura un OS en 5 minutos desde un DVD….
Le pongo todas las fichas, ademas no es un programita free sin soporte, fijate que tambien ofrece la version enterprise para levantar imagenes de la Red
En mi anterior laburo migramos del ghost al acronis despues de que lo probamos…
leansms
entradas: 1417
09:57 12/08/2009
Si la verdad ahora que conoci el Acronis me quedo con este, encima en español, y re rapido, espero que el dia que tenga que restaurar lo haga todo bien, esta muy recomendado por todos en la red, asi que por algo sera
