Duda sobre conexion USB de disco de 3.5???
Hola que tal, estuve averiguand para comprar un cable para conectar el disco por USB.
El disco es un WD de 750gb y segun el disco consume 5v a 0.5A.
Ahora bien, estuve averiguando y en teoria el puerto usb da un maximo de 500mA
USB powered devices
The USB connector provides a single 5 volt wire from which connected USB devices may power themselves. A given segment of the bus is specified to deliver up to 500 mA. This is often enough to power several devices, although this budget must be shared among all devices downstream of an unpowered hub. A bus-powered device may use as much of that power as allowed by the port it is plugged into.
Bus-powered hubs can continue to distribute the bus provided power to connected devices but the USB specification only allows for a single level of bus-powered devices from a bus-powered hub. This disallows connection of a bus-powered hub to another bus-powered hub. Many hubs include external power supplies which will power devices connected through them without taking power from the bus. Devices that need more than 500 mA or higher than 5 volts must provide their own power.
Osea que si conecto el disco me da la impresion que no va a moverlo bien, porque el disco consume 0,5A y el puerto usb da, hasta 0,5A, osea que me da la impresion que puede llegar a quedarse corto, ya con que no el el 100% de amperaje ya no me moveria el disco no?
Alguno probo conectar un disco de 3.5' con similar amperaje de consumo por usb sin adaptador externo de energia y le funciono?
aca mas info
USB power usage:
Bus-powered hubs: Draw Max 100 mA at power up and 500 mA normally.
Self-powered hubs: Draw Max 100 mA, must supply 500 mA to each port.
Low power, bus-powered functions: Draw Max 100 mA.
High power, bus-powered functions: Self-powered hubs: Draw Max 100 mA, must supply 500 mA to each port.
Self-powered functions: Draw Max 100 mA.
Suspended device: Max 0.5 mA
Gracias
andres2420
entradas: 880
02:42 18/10/2010
Necesariamente tiene que ser sin adaptador externo de energia? Porque yo compre hace un par de meses este y nunca un problema ( lo probe tanto con sata 2.5/3.5 y con disco ide 3.5).
Yo tengo uno de esos. Los discos pata de notebook, andan perfecto con el adaptador, sin alimentación externa. Ahora, los discos sata y pata comunes, necesitan las líneas de 12v sí o sí. Sin adaptador, olvidate que funcionen…
Cita Iniciado por andres2420
Cita Iniciado por tux_topo
Buenas, gracias por las respuestas, y si por lo que veo para mover uno de 3,5 voy a tener q usarlo con conexion externa de energia
Respecto a los de 2,5', si eso habia leido Tux, pero mi esperanza era q ese tambien anduviera, pero por los requerimientos que tiraba de consumo el de 3,5 en A me parecia que no.
Bueno ultima duda, mi disco de 3,5 es un WD de 750gb y acusa los siguientes consumos tanto en 12 como 5v:
12v 0,7A
5v 0,5A
Buen segun lei el puerto firewire da 12v, lo que no busque aun, cuantos ampers da. Voy a ver si viene algun cable adaptador de la conexion de energia de 15pin sata a firewire y si es posible conectar energia por firewire y el disco para sata a esata (si ya se quedaria medio injerto ajajaja)
O sino voy a buscar a ver si hay forma de conectar a 2 usb el disco. Si saben del tema les agradezco
Mirá, sé que algunos discos rígidos portátiles lo hacen. Pero son discos de 2.5". No creo que puedas con discos de 3.5"….
De todos modos, si llegás a averiguar algo, chflá que está buena la idea!!
gracias Tux, voy a averiguar en la semana a ver si saco algo en limpio, ahora toy viendo Dexter ( y siguen otras 3 series despues jajaja)
Nos vemos
